Roll cage material - Interior Works - DiecastXchange.com Diecast Cars Forums
Roll cage material
4 replies to this topic
#1 OFFLINE   vinnyvangough
vinnyvangough
  • 61 posts
  • Interests:Motorsports
  • Favorite Brands:Sunstar
Posted 12 June 2014 - 01:07 PM
What do you guys use to build custom roll cages?
#2 OFFLINE   mairandeddy
  • 23366 posts
Posted 12 June 2014 - 01:31 PM
I've not made a roll cage myself but have seen modders use the single solid core copper house wiring, as this can be easily soldered.....
....I have also seen people use fine drinking straws, or the tubing used for WD-40 nozzles..you can put wire inside these to shape them...
....Plastic sprues from model kits can also be used if the correct profile - can be quite easily bent and glued.....
Hope this helps :hope:
#3 OFFLINE   vinnyvangough
vinnyvangough
  • 61 posts
Posted 12 June 2014 - 01:44 PM
Some good ideas there. Saw some rods another modeller was using but can't find them on eBay or remember the name of them now
#4 OFFLINE   Nocky
Nocky
  • 5254 posts
  • Favorite Brands:Bburago
  • Proud Citizen of: nz
Posted 13 June 2014 - 05:25 AM
Try Evergreen or Plastruct for scale model plastic tubing. Anything plastic or metal the right size can be used. Plastic tubing with a metal rod inserted in it can be bent to shape easily.
Search in the Custom Resources area as there is info there too.
Custom Diecast, Just DO IT!
#5 OFFLINE   vinnyvangough
vinnyvangough
  • 61 posts
Posted 13 June 2014 - 12:30 PM
Cheers. Just ordered some
