Wheel painting? - Wheels, Brakes and Stance works - DiecastXchange.com Diecast Cars Forums
Wheel painting?
8 replies to this topic
#1 OFFLINE   Eric
Eric
  • 2739 posts
  • Interests:Diecast
  • Favorite Brands:AUTOart, Kyosho, & GT Spirit
Posted 05 August 2017 - 08:33 AM
I'm currently in the process of de-chroming a set of wheels before painting them black.  I did a test chrome wheel using a product called Grease Lighting Cleaner which come in a pump spray bottle and it worked quite well at removing the chrome paint.  My question is I want to be able to preserve the Lamborghini emblem in the center of my wheel, if possible.
What do you guys use to cover or protect the emblems?
#2 OFFLINE   slartibartfast229
slartibartfast229
  • 4623 posts
  • Favorite Brands:Otto
  • Proud Citizen of: ie
Posted 05 August 2017 - 11:59 AM
If you are talking about spraying the paint on to the wheels - a dab of my 'go to' for all sorts of things - white/pva/wood glue.
Should not leave any residue if kept out of strong sunlight.
It might even protect the emblem from the chrome cleaner - test it first!
Edited by slartibartfast229, 05 August 2017 - 12:01 PM.
#3 OFFLINE   Eric
Eric
  • 2739 posts
  • Interests:Diecast
Posted 05 August 2017 - 12:42 PM
Thanks for the reply.  So you're just putting a drop of wood glue over the decal and letting it dry?  I never though of doing that.
Hopefully, the cleaner doesn't just dissolve the glue.
#4 OFFLINE   slartibartfast229
slartibartfast229
  • 4623 posts
Posted 05 August 2017 - 04:06 PM
Test it!
Place a blob of the glue onto a piece of waste material, and leave it so soak in the cleaner.
If it dissolves, try something else.
There appears to be a layer of varnish over the cap, protecting the decal, but you don't want that to be damaged either.
Why not use a piece of 1000 grit sandpaper on the chrome to 'score' it, to help with paint adhesion?
In the case of what you are doing, it would probably be my preference.
I have done this several times with overly chromed rims on bBurago models, painting them with an automotive silver.
It has not failed me so far.
I would recommend a flat black base followed by a gloss - if it's gloss you are going for (or perhaps a satin).
#5 OFFLINE   Eric
Eric
  • 2739 posts
  • Interests:Diecast
Posted 05 August 2017 - 04:45 PM
Thanks, I am testing it on a spare wheel.
#6 OFFLINE   Eric
Eric
  • 2739 posts
  • Interests:Diecast
Posted 07 August 2017 - 12:11 PM
Well the dried wood glue didn't survive the oven cleaner test but fortunately the decal did.  So I went ahead and soaked the chrome wheels in the oven cleaner liquid and in five minutes all of the chrome was completely dissolved and the decals remained intact.
However, I did make a slight mistake.  The first wheel I let soak for one hour and I didn't check on it in that hour so the decal took a beating but the plastic was fine.  I watched the other 3 wheels and the chrome was completely gone within 5 minutes.
Edited by Eric, 07 August 2017 - 12:13 PM.
#7 OFFLINE   slartibartfast229
slartibartfast229
  • 4623 posts
Posted 07 August 2017 - 02:06 PM
Too bad about one of the wheels.
If you want to try a replacement decal for the damaged rim, look at this decal sheet:
http://www.coloradod...Grup=3&prod=551
It's designed for 1/24th scale, and there are four on the sheet which could well be the correct size for a 1/18th scale wheel hub.
#8 OFFLINE   Eric
Eric
  • 2739 posts
  • Interests:Diecast
Posted 07 August 2017 - 02:35 PM
I already have a sheet of 1:18 replacement decals for it.  :)
#9 OFFLINE   spikyone
spikyone
  • 1720 posts
  • Favorite Brands:AutoArt, Spark, TSM
Posted 08 August 2017 - 03:54 AM
That's a massive improvement on those rims, and great advice on de-chroming. :occasion14:
*** Collection thread (to be updated) ***
