Help: How to remove wheel stubs - Disassembling - DiecastXchange.com Diecast Cars Forums
5 replies to this topic
#1 OFFLINE   thebigmacmoomin
thebigmacmoomin
  • 689 posts
  • Interests:Cars, Football, Motorsports
  • Favorite Brands:All of them
Posted 12 December 2017 - 02:15 PM
Hi all,
I'm in need of some help.
I have recently purchased a set of black Nismo R34 Z-Tune wheels to go onto my AutoArt Skyline R34. However, the wheels have the original stubs / pins stuck in the hole, as per the attached photo.
Any idea's on how to remove them as I would like to keep the wheels rotating when fitted. There doesn't appear to be enough sticking out to attach some pliers to pull it out.
I did think drill a hole but I don't want to risk that.
Thanks
Andrew
All of my modified models : https://[email protected]/sets/
#2 OFFLINE   StratosWRC
StratosWRC
  • 8955 posts
Posted 12 December 2017 - 02:19 PM
Heat it up with a lighter for 5 seconds or so. Grab it with the pliers and gently rotate it out. When I say rotate I mean pull at the same time
Edited by StratosWRC, 12 December 2017 - 02:22 PM.
I mod stuff
Wes
#3 OFFLINE   thebigmacmoomin
thebigmacmoomin
  • 689 posts
Posted 12 December 2017 - 04:16 PM
Thanks, will give that a try.
#4 ONLINE   BaseGTR
BaseGTR
  • 1550 posts
Posted 12 December 2017 - 05:37 PM
Can't see your pics, but it sounds like the brake hub bit is stuck on the wheels. You'll have to remove that using Wes' method and then you'll have access to push the pin out from the other side.
Edited by baseb8, 12 December 2017 - 05:47 PM.
Base
@basegtr
#5 OFFLINE   thebigmacmoomin
thebigmacmoomin
  • 689 posts
Posted 13 December 2017 - 11:31 AM
It says error but i did it as an attachment so I dont know why.
Whats the Wes' method?
Edited by thebigmacmoomin, 13 December 2017 - 11:33 AM.
#6 ONLINE   BaseGTR
BaseGTR
  • 1550 posts
Posted 13 December 2017 - 03:06 PM
Is it like this?
(Picture from Floper54)
Pretty much what Wes wrote here, the brake hub is usually on quite strong and it's easy to deform it.
Edited by baseb8, 13 December 2017 - 09:38 PM.
Base
@basegtr
