Gallardo Performante Spyder - AUTOart with parts from Norev - ROBSMC's Portfolio - DiecastXchange.com Diecast Cars Forums
63 replies to this topic
#1 OFFLINE   ROBSMC
ROBSMC
  • 2396 posts
  • Interests:Motorsport, building race cars, collecting 1/18 model cars and building custom models, collecting watches and sneakers
    My Youtube channel - Robs Model Cars
    Facebook @RobsModelCars
    Instagram @RobsModelCars
  • Number of Models:Last count over 200
  • Favorite Brands:bbr, mr, frontiart, autoart
Posted 07 February 2020 - 10:55 PM
I find it very strange that AUTOart made so many variations of the Lamborghini Gallardo coupe, but never made the spyder. Well, again I will fill the slot and build my own. I have a extensively modified Bburago 1st gen Gallardo Spyder, so this time I will be building a replica of the later model Performante spyder which is basically a open top version of the Superleggera. I am using an AUTOart Gallardo Superleggera that I got off eBay cheap, and a Norev LP560 spyder that I got off eBay for 15 euros as it had no box and some glued repairs and missing emblems. Perfect as a parts car.
Now originally I was just going to buy a perfect condition Norev Gallardo Spyder and modify that, but the more I researched the car, the more I realised that sooo much was different and I couldn't buy all the extra parts I needed from AUTOart spares anyway. Plus the Norev has a sealed front hood and has poor detail compared to the AUTOart model. So the decision was made to use an AUTOart Superleggera and chop off the top. Everything else on the AUTOart model is exactly as the pictured Performante Spyder, wheels, seats, bumpers, diffusers, interior and seats, so hopefully the roof chop is really the only big modification and fitting the spyder engine lid and a repaint. Fingers crossed. Here is the car I am replicating.
And here is the base model, AUTOart Superleggera in grey, got this for $110 used but it is in mint condition.
And here is the Norev 15 euro Spyder that I got off ebay too. I will be staling parts off this model and fit them to the AUTOart model. That's the plan anyway.
The AUTOart model has so much better detail than the Norev, plus it fully opens up, and has all the correct aero, wheels and interior to match the Perfomante Spyder
I think mostly I will be using the rear engine lid, convertible top, engine bay top tray and airbox extensions, and maybe some of the diecast frame of the engine bay. I want to remove the big dogleg hinges too off the engine lid and try to fit AUTOart hinges
AUTOart model disassembled and this took some time, as a lot of parts on this model were glued
Norev model disassembled, in contrast to the AUTOart model, this only took 10 minutes to pull apart. So simple.
Mostly needed the model for these parts, so for 15 euro, not too bad. Plus I will sell off the other parts like whole interior assembly, wheels and some other bits and pieces
Next will be to start cutting away the roof off the AUTOart model to retro fit the Norev engine lid. I will take my time with this as I don't want to cut away too much on the AUTOart body. This will be in the next update. Thanks for looking. Cheers
#2 ONLINE   T1000
T1000
  • 4015 posts
  • Interests:Diecasts and 1:1s
  • Proud Citizen of: bg
Posted 08 February 2020 - 01:12 AM
This one is going to be interesting :drool5:
I'll be back
#3 OFFLINE   Upgrades
Upgrades
  • 454 posts
  • Favorite Brands:Autoart, Kyosho, CMC, GMP, etc.
  • Proud Citizen of: nl
Posted 08 February 2020 - 10:49 AM
This is completely in my street. Still on my list to do, can't wait how you gonna attack this one. I'm sure it's gonna look stunning.
#4 OFFLINE   preisman
preisman
  • 12430 posts
Posted 08 February 2020 - 11:17 AM
This will be cool. I would totally want one of these.
#5 OFFLINE   msousa71
msousa71
  • 159 posts
  • Favorite Brands:lamborghini
Posted 08 February 2020 - 12:50 PM
Another amazing project, your talented !!..I want to mod my white Maisto Gallardo convertibe with some upgrades etched grills some paint on wheels and some other detail work and the same stripes as the one you pictured above but without the Superleggera detail ...Is TK going to do decals for you if so let him know I am in for an order also
#6 OFFLINE   Craig
  • 31885 posts
Posted 08 February 2020 - 04:22 PM
Great project!!
Can you use small magnets for the engine cover ? AUTOart did that on some of their Gallardo models.
F**k you Photobucket.
#7 OFFLINE   ROBSMC
ROBSMC
  • 2396 posts
Posted 13 February 2020 - 01:44 AM
Thanks fella's,
UPDATE 13/02/2020
Since it has been raining here for the last week straight and I can't paint my Diablo project, I thought I would make a start on this roof chop. Just compared a lot of the sizes and lengths of all the edges on the Norev rear engine lid and worked out some cut lines on the AUTOart body
I want to try and keep these screw posts so will cut away the top diecast in a second round. I will also under cut the top of the front window frame so I can trim that to the correct size after I get the rear engine lid right
I used the Dremel with a thin cut off wheel to cut off the roof. I went through a few disc's but got the job done
Just sitting the roof on top to have a look at the size comparison of the body lines
More to cut of on the sides to drop the front down
Luckily the diecast screw posts on the inside of the body are joined there too, so I was able to cut away the tops of the body
Everything is just rough cut and will need to be filed and filled to clean them up,
Norev engine lid fits in with a little bit of force at the front, which means I will have to file out the front sections and check again. If it is still tight, I will have to trim the engine cover to make it fit
Even with this rough cutting away of the body, It is going to fit and all the edges seem to line up even at this stage.
Front corners still need to come down a bit, but so far so good
Quick check with a door sitting in place and again, all signs look promising. I will have to add the small door extension piece at the back which blends the door into the engine cover. Pretty happy with the progress this afternoon. More to come. Thanks for looking. Cheers
#8 ONLINE   T1000
T1000
  • 4015 posts
Posted 13 February 2020 - 02:29 AM
You make it look as easy as making a cardboard model, lol.
I'll be back
#9 OFFLINE   ROBSMC
ROBSMC
  • 2396 posts
Posted 13 February 2020 - 05:26 AM
Thanks T, although really I just chop into it with the Dremel and hope it goes well. In this case the AUTOart Gallardo and Norev Gallardo are almost identical in size, which is good for 2 seperate companies to make a 1/18 scale model that is true to scale.
#10 OFFLINE   ROBSMC
ROBSMC
  • 2396 posts
Posted 13 February 2020 - 11:25 PM
UPDATE 14/02/2020
Today I decided to strip all the paint off the body and parts as it was a bit hard to see where to keep trimming to make the engine lid fit due to the dark grey color of the body. So out with the water based paint stripper and removed all the paint which didn't take much as the AUTOart paint on this model peeled of in minutes.
Now I can see better where the engine lid needs more clearance and where I have more work to do.
Out with the dremel again and I removed alot more diecast from the inside front diecast pillars and trimmed the width to the original body line
Engine lid now fits in place flush with the top edges. Sweet
Next I just sat in the interior tub assembly to see where it finished. You can see the two narrow vertical posts behind the seats, these went either side of the rear window and will foul the engine lid, so I cut these off
The engine lid now sits in place and does not foul the interior tub. So far, so good, just sat the body on the chassis and put the doors and hood in place to get a look. That is alot of progress in a very short time. More to come. Cheers
Edited by ROBSMC, 14 February 2020 - 02:43 AM.
#11 OFFLINE   Craig
  • 31885 posts
Posted 14 February 2020 - 07:57 AM
Good progress there Rob!! I can't for it, it's going to look damn sweet! :yahoo: :yahoo: :yahoo:
#12 OFFLINE   Out of Gear
Out of Gear
    They look better in real life.
  • 346 posts
  • Interests:Music, videogames, basketball, tennis, cars, cycling
  • Number of Models:~40
  • Favorite Brands:AutoArt, Kyosho, HPI, Exoto
Posted 14 February 2020 - 04:32 PM
Exciting stuff Rob! I remember there were some differences between the nose shape (Performante is sharper and more pointed) and other potential minor details across the AUTOart Superleggera and AUTOart Supertrofeo Stradale, will you be reconciling some of that with this build as well?
Edited by Out of Gear, 14 February 2020 - 04:36 PM.
Come to my house to see my collection!
#13 OFFLINE   ROBSMC
ROBSMC
  • 2396 posts
Posted 14 February 2020 - 04:56 PM
Cheers Craig, just chopping the roof off and getting the lid to fit was relatively easy.
Yes, the nose is more pointed and I will be adding that, the other vents and skirt shape and rear diffuser and wing are all the same as the Superleggera, so that will stay as it is. Just the pointed front bumper and the Spyder conversion is all  need to do for this build
#14 OFFLINE   msousa71
msousa71
  • 159 posts
Posted 15 February 2020 - 08:41 AM
:omg: Allot of work on this one Rob ...but your making amazing progress your talented , this one does not look easy  ..its going to turn out amazing from what i see  so far, loving the  progress pics !!!
#15 OFFLINE   Upgrades
Upgrades
  • 454 posts
Posted 15 February 2020 - 03:47 PM
Amazing job Rob, the bare metal on the last picture already look stunning to me.
#16 OFFLINE   BaseGTR
BaseGTR
  • 1636 posts
Posted 16 February 2020 - 02:05 AM
Nice job there Rob, be good to see if you can make the Autoart hinges work on the engine lid.
Base
@basegtr
#17 OFFLINE   ROBSMC
ROBSMC
  • 2396 posts
Posted 18 February 2020 - 12:52 AM
UPDATE 18/02/2020
Playing around with some AUTOart Huayra rear engine lid hinges. I think these will work, but it will depend on how well a bond I get glueing them to the diecast. I don't think a superglue will work long term, so maybe I need to try a 2 part epoxy to get them on there solid.
I will have to make some holes either side in the engine assembly to sink the base of the hinges down lower, but you get the idea of how this should end up. The weight of the engine lid will stop it from staying up by itself, so not sure how much of this mod will be worth it.
Next I plan to add some putty to the front nose area to re shape it to the Performante front bumper. So I drilled some small holes hoping the putty grabs better to the diecast
Tamiya quick set putty mixed and applied to the front bumper.
And I had to add some to the rear sections either side as I filed back the metal here too far before I had really checked the fitment of the engine lid. Rule here for next time. Don't work on a custom model late at night when you are tired! Anyway, more to come soon. Cheers
#18 OFFLINE   msousa71
msousa71
  • 159 posts
Posted 18 February 2020 - 09:26 AM
Rob not sure if you know about this product but this would be the best epoxy type product to use its super strong bonds incredibly well to metal and plastic and drys almost like metal and its sandable super strong
#19 ONLINE   T1000
T1000
  • 4015 posts
Posted 18 February 2020 - 10:41 AM
I've used epoxy to fix a broken A-pillar on a model, worked like a charm. So, definitely explore it for your model :agreed:
I'll be back
#20 OFFLINE   genkov4336
genkov4336
  • 127 posts
  • Favorite Brands:kyosho,bbr.AUTOart
Posted 18 February 2020 - 11:16 AM
If you have a model gallardo 1:18 STS autoart  you  can use it  for example to make the front bumper shapes.Gallardo  STS is correct comparisons to the regular gallardo version which you  have used for the basic model or you could make a casting and then stick it.
Edited by genkov4336, 18 February 2020 - 01:00 PM.
#21 OFFLINE   ROBSMC
ROBSMC
  • 2396 posts
Posted 22 February 2020 - 12:42 AM
Thanks for the tip, I can get that glue here in Australia, so I will get some tomorrow. Cheers
Cheers, I will.
I have the STS and have used that for the dimensions. Cheers
#22 OFFLINE   ROBSMC
ROBSMC
  • 2396 posts
Posted 22 February 2020 - 01:08 AM
UPDATE 22/02/2020
Made some more progress today by starting to shape the putty add on's. I first used a sharp blade to cut some of the bulk away.
I then sanded the putty back to shape in the rear to meet the rear engine lid. Not much putty left but it filled the uneven gaps
I then sanded down the bulk of the putty on the nose extension and then fitted the front hood and marked the center line
I then made a cardboard template of the nose shape of the STS Gallardo and traced the front edge on the putty and will sand it back to that edge
Lots of sanding to get it very close to the shape of the STS bumper
I kept refering back to the STS bumper to get the shape right and am nearly there
A quick coat of grey primer to check what further work needs to be done. Just a light skim of Tamiya filler and it should be done.
Same with the back, just a light skim and this will be done
Now this is the Norev engine plastic bits sitting in the Norev body. I have to transfer alot of this into the AUTOart body
Here is the AUTOart engine in the AUTOart diecast body. Quite different and this is going to take quite a bit of work to make it fit
I started by cutting of the front sides of the AUTOart engine assembly to fit the Spyder top recess box
This is how it sort of fits
I then decided that the AUTOart engine was not going to work, so I cut that out of the AUTOart rear frame as I still want to keep that as it has the wheel well liners and rear locating tabs that will keep it in the right position under the AUTOart body
Quite a bit of trimming of the AUTOart rear tub frame and this is the Norev spyder top box and Norev engine/airbox assembly sitting in place
That new assembly sitting in under the body and fits pretty well
Engine lid fits in place and does not foul it. So far so good
Next is the spyder top box which has to drop down alot more to fit under the engine lid. This is going to require more diecast cut out including more off the top of the screw pin castings. These are only connected to the body at the top, so if I cut much more of these, they will simply fall off. I need to keep these as these are the main assembly points for the whole floor assembly, so I am going to have to get creative
So in the side voids after the interior and engine tub get inserted, I applied a generous amount of Tamiya 2 part putty to join the screw pin castings into the sides of the body. I should now be able to cut away another 2mm of diecast off the top and these and they should stay joined to the body. Fingers crossed. This part of the build is a lot more complicated that first thought when I planned this build. More to come. Cheers
#23 ONLINE   T1000
T1000
  • 4015 posts
Posted 22 February 2020 - 02:04 AM
If the screw castings fall off, you can re-attach them with the epoxy. It should glue them to the sides, quite nicely and firmly.
As for the rest. Quite a lot of work, wowza. But now you have an extra AUTOart Lambo engine, too :yahoo:
I'll be back
#24 OFFLINE   Maarten Mercedes
Maarten Mercedes
  • 593 posts
  • Favorite Brands:AutoArt, BOS, CMC, KK-scale, Norev, Ottomobile
Posted 22 February 2020 - 06:20 AM
What a great job you are doing here. The attention to detail is outstanding!
Maarten
Flickr
#25 OFFLINE   msousa71
msousa71
  • 159 posts
Posted 22 February 2020 - 07:05 AM
Alot of ingenuity Rob always looking forward to seeing these updates , the front bumper is looking bang on !!!
