Scratch building 1:18 40ft Flat bed for NZG Actros - DX Custom Model Tuner Shop - DiecastXchange.com Diecast Cars Forums
31 replies to this topic
#1 OFFLINE   channabasanna
channabasanna
  • 386 posts
  • Interests:Scalemodel cars, Formula 1, Cricket, Gaming, Drawing, Painting, doing Crafts
  • Favorite Brands:Welly, Autoart, Kyosho
  • Proud Citizen of:†in
Posted 24 August 2020 - 09:05 AM
I have the NZG Actros, and when NZG announced the are Car Transporter i was eager to get it but the price was too much for me. Meanwhile KK Scale started releasing the truck rear tyre set hence i thought i will make use of MDF boards available from the 2 dollar shop and few mdf rectangle pieces.
Trying to get it in scale of 1:18 as far as possible and this is my first build of something for 1:18 from scratch.
Brought 2 40cmx15cm MDF boards (using the 15cm width since the NZG truck is almost ~15cm in width), and few KK truck rear tyre set.
Did find that the 40 foot flat bet trailer total length is 69cm in 1:18 scale. Hence used the dremel and cut one board to 29cm.
Drilled a hole in the center at 5cm from one end for connecting with the Truck.
Added square rods for entire length of the joined boards to added support and used 1/2 inch screws. Need to change them to bit more longer screws.
Sample test with the truck and tyre set
Expecting it to come somewhat like this
More to come, will use all your feedback as much possible.
#2 OFFLINE   ibj40
ibj40
  • 5131 posts
  • Favorite Brands:.
  • Proud Citizen of:†us
Posted 24 August 2020 - 12:34 PM
Going to be following this.
Very ambitious project.
I have two of the trucks, but like you, havenít been able to put together the coin to buy one of the pre-built ones.
Good Luck!
#3 OFFLINE   Craig
  • 31736 posts
  • Proud Citizen of:†gb
Posted 24 August 2020 - 02:05 PM
It looks pretty good so far, a bit 'planky' though. I think it needs a headboard or something at the cab end, and some crash bars underneath it in front of the wheels.
It has potential though :)
F**k you Photobucket.
#4 ONLINE   vulpex
vulpex
  • 2130 posts
  • Proud Citizen of:†de
Posted 24 August 2020 - 02:38 PM
Promissing start, channabasanna!! :eusa_clap:
With some detailing like Craig already mentioned and lots of silver paint this should become a good alternative to those pricey trailers...
#5 OFFLINE   channabasanna
channabasanna
  • 386 posts
Posted 24 August 2020 - 08:21 PM
I have two of the trucks, but like you, haven't been able to put together the coin to buy one of the pre-built ones.
Good Luck!
Thank you ibj40
Thank you Craig, have plans to add a plank in the front and also crash bars as you said, will try adding few tail lights also.
Thank you Vulpex. Will be adding few more details, as you suggested i will be considering Silver paint on the Flat bed. Planning to have a yellow or light green on the sides. Any suggestions on the colors.
#6 OFFLINE   T1000
T1000
  • 3989 posts
  • Interests:Diecasts and 1:1s
  • Proud Citizen of:†bg
Posted 24 August 2020 - 11:23 PM
This is going to be interesting :yahoo: :drool5:
I'll be back
#7 OFFLINE   Sebastian
Sebastian
  • 117 posts
  • Favorite Brands:AutoArt
Posted 27 August 2020 - 11:15 PM
Nice project here. Will follow that :lurker:
#8 OFFLINE   badday65
badday65
  • 5 posts
  • Favorite Brands:Sunstar
Posted 28 August 2020 - 02:37 AM
Good work, will be keeping an eye on your progress
#9 OFFLINE   channabasanna
channabasanna
  • 386 posts
Posted 01 September 2020 - 09:37 AM
Thank you T1000
Thank you Sebastian
Thank you badday65
Updates on the Flatbed trailer:
Added few Horizontal wooden pieces for more strength. I used more 5/8 screws to fix the wood well.
Made a rectangular block to support the trailer wheels and temporarily added them. Through it is not realistic
Wheels added, will need to create wheel arches
Used a 1/2 inch screw as Kingpin to connect to the trailer
Test fit
Size comparison
Will be adding:
1. Wheel arches
2. Side railings
3. Rear lights (will try adding LED)
4. Rear crash bar
5. Trailer stand (No idea what it is called)
6. Few boxes.
7. Add some putty and paint the trailer.
Edited by channabasanna, 01 September 2020 - 09:38 AM.
#10 OFFLINE   ibj40
ibj40
  • 5131 posts
  • Favorite Brands:.
Posted 01 September 2020 - 12:54 PM
Keep up the good work.
Edited by ibj40, 01 September 2020 - 12:54 PM.
#11 OFFLINE   lateapex
lateapex
  • 2921 posts
  • Number of Models:70-80
  • Proud Citizen of:†no
Posted 02 September 2020 - 10:09 AM
I sometimes forget how big these are since I have never seen one in real life, but with models on the trailer it becomes obvious.
Top tip on lights for the trailer, look at autoartspares (when it reopens), generic looking lights from random cars can suddenly fit the purpose.
#12 OFFLINE   BaseGTR
BaseGTR
  • 1621 posts
Posted 02 September 2020 - 10:14 AM
Great progress on this so far!
Base
@basegtr
#13 OFFLINE   channabasanna
channabasanna
  • 386 posts
Posted 02 September 2020 - 09:19 PM
Thank you ibj40
Thank you lateapex, will do wait for the autoartspares to be back online. and Look through their site.
Thank you BaseGTR
#14 OFFLINE   channabasanna
channabasanna
  • 386 posts
Posted 12 September 2020 - 01:18 AM
[U}Built the rear crash bar[/U]
[U}Built the side railings[/U]: Built side railings for two sides, one side i made it shorter to add a tool box
Cut the small wooden sticks in same length, before making one shorter
Similarly cut 8 pieces to fix the railings to the trailer.
The Side railings are ready
Attaching the side railings to the trailer, using UHU Glue i did stick them before screwing them with 1/2" screws
Completed with adding the side railings
[U}Test fit with Actros[/B]
Tested the trailer to make sure it turns well
#15 ONLINE   vulpex
vulpex
  • 2130 posts
Posted 12 September 2020 - 03:02 AM
Good progress here, channabasanna - looks more and more like a real thing! :eusa_clap:
Do you plan to use some kind of filler and sand the whole thing or just paint the wood as it is?
#16 OFFLINE   D N'D-Land
D N'D-Land
  • 11691 posts
Posted 12 September 2020 - 10:20 PM
That is just some EXCELLENT craftsmanship! :eusa_clap: :eusa_clap: :eusa_clap: :eusa_clap: .. GREAT JOB!!! :occasion14:
Make the Best Out of Life!
#17 OFFLINE   channabasanna
channabasanna
  • 386 posts
Posted 13 September 2020 - 04:18 AM
Thank you Vulpex, Will probably use Tamiya putty and paint it with some automotive spray cans.
Thank you David :-)
Built the box for the trailer and fixed it made it to open and close with a Paper clip.
#18 OFFLINE   channabasanna
channabasanna
  • 386 posts
Posted 15 September 2020 - 07:41 PM
Removed the previously built box for the trailer has it had lot of gaps
Brought some 3mm Balsa wood from Art & Friend shop here and since it was off day for me to office, spent time in building this. Will need to cover the holes using puttty.
The initial box was built
The box door is being built
Test fit of the door to the box
Drilled holes in the side of the box wall, used some paper clips and a drinking straw for door opening mechanism. (The pink and blue pieces in the below pics are of the different paper clips)
Glued to the trailer
#19 OFFLINE   channabasanna
channabasanna
  • 386 posts
Posted 03 October 2020 - 04:21 AM
Trailer tail lights.
Initially planned to make it as a boxed lights but then changed to round lights.
The round lights: Used some transparent round stickers which are actually some furniture protectors on a medicine covers to get the inside texture, then used Tamiya clear orange and clear red as indicator and stop lights
Test fit on the trailer (Just to see how it looks, this is not the final position of the lights)
Trailer wheel arches
Used a 1 litre White milk plastic bottle then cut them into strips
Marked the Wheel arch positions, this was the initial marking i did, using a pencil around the tyre and it was sitting pretty low on the tyres. Then re marked the position and fixed them using Fevikwik. Will be painted later to flat black.
Now after new marking flued to the flatbed using fevikwik and it stuck well. Pics of the wheel arches with the tyres on the trailer.
Still to be done:
The Landing legs
Painting the trailer.
#20 OFFLINE   jusali
jusali
  • 1346 posts
  • Favorite Brands:Too many to choose from
Posted 03 October 2020 - 05:25 AM
Good stuff, can't wait for the paint!
#21 OFFLINE   T1000
T1000
  • 3989 posts
Posted 03 October 2020 - 05:55 AM
Fantastic progress :eusa_clap:
I'll be back
#22 OFFLINE   channabasanna
channabasanna
  • 386 posts
Posted 03 October 2020 - 09:37 AM
Thank you jusali.
Thank you T1000.
Any suggestions for the color to the trailer.
#23 OFFLINE   T1000
T1000
  • 3989 posts
Posted 03 October 2020 - 10:22 AM
Ideally the trailer color should match the truck, in my opinion :occasion14: Or something in a complimenting  brigher color if you want it to stand out.
I'll be back
#24 OFFLINE   ibj40
ibj40
  • 5131 posts
  • Favorite Brands:.
Posted 03 October 2020 - 11:41 AM
Good job and lots of ingenuity in your approach.
Looking really professional.
#25 ONLINE   vulpex
vulpex
  • 2130 posts
Posted 04 October 2020 - 01:44 AM
Getting better and better!! :eusa_clap:
Difficult to give an suggestion for the colour - of course you have to keep your truck in mind.
What I would probably do is a bit of research in google pictures until I find an inspirering example...
