If anyone that has a Maisto Mercedes S Class sedan and a Maisto Mercedes SLR, could you look to see if the wheels from the SLR look like they would fit inside the wheelwells of the S Class?
Thanks!
The front wheels pose no problems both height and widthwise. The rear wheels of the SLR will be a tight fit on the S class because of the width (2-3 mm wider). The lower wishbone which is screwed to the spring may pose a slight problem if any. There might be only a tiny clearance between the part and the rear brake assembly.
Related Threads
DiecastXchange Forum
1M posts
14.9K members
Since 2003
A forum community dedicated to diecast owners and enthusiasts. Come join the discussion about collections, displays, models, styles, scales, reviews, accessories, classifieds, and more!
