Cheap carpeting -not flocking *topics merged* - Interior Works - DiecastXchange.com Diecast Cars Forums
27 replies to this topic
#1 OFFLINE   T1000
T1000
  • 3944 posts
  • Interests:Diecasts and 1:1s
  • Proud Citizen of: bg
Posted 26 January 2009 - 01:11 PM
I was quite surprised that my simple carpeting technique gathered so much interest, but lately I've been asked several times on how and what do I do to my models so I decided to do a quick tutorial when doing my next "inside job" :giggle  I hope you'll find it usefull for something  :cheers
I'll use the forum attachment system so that the pics will be always available so excuse me for the several posts  :storm
Of course first we need a model. In this case I chose the regular F360 by Hot Wheels.
This is before it all began:
Attached File  IMG_0931___.jpg   44.93K   15 downloads
In most models separating the interior from the underside of the car is no big deal but for some reason Hot Wheels decided to glue it on here  :mob By separating the pieces work is significantly simplyfied but it's not the end of the world if you don't/can't do it.
Next we take the carpet. In my case it's a very thin layer of velour.
Attached File  IMG_0933___.jpg   38.99K   15 downloads
Then it's time for the first test fit. I know that with paper it'll be much easier and quicker but by cutting directly the velour I can see all potential problems, where I'll have to cut extra in order to fit it snugly into the car and the rest of the interior. Also you have an instant preview of what's going on so you can make instant corrections if needed:
Attached File  IMG_0927___.jpg   49.56K   13 downloads
By doing this I haven't scrapped a single sheet of velour yet and I've done 14 cars so far so that's a nice rate   :cheers
More to follow in a bit.
I'll be back
#2 OFFLINE   T1000
T1000
  • 3944 posts
Posted 26 January 2009 - 01:22 PM
After a lot of carefull cutting here's the final shape for the driver's side floor.
Attached File  IMG_0935___.jpg   46.81K   11 downloads
Usually when you separate the interior from the underside you're able to remove the seats as well. Now that here this wasn't possible I had to cut a huge hole in order to put the carpet arround the seat as well.
In models where you're able to remove the seats cutting holes is also needed. Of course in that case they are much smaller - just arround the screw/rail mounting by doing this you allow the free reassembling of the seats later but in the same time they hold the velour down so it's extra safe :ok
Now we do a final test fit:
Attached File  testfit___.JPG   36.37K   11 downloads
Then you cut double sided tape and place it near the edges and dead in the centre of the flood. Sorry but I forgot to take a pic of that... :storm But you get the idea  :cheers
Now in this case the seat is not holding the velour down so I had to cut a small piece of tape and attach it to the soon-to-be carpet. Then with a small pin I put it in the correct place in the left and right of the seat.
Attached File  IMG_0937___.jpg   41.57K   13 downloads
Getting closer to the grande finale  :giggle
I'll be back
#3 OFFLINE   T1000
T1000
  • 3944 posts
Posted 26 January 2009 - 01:34 PM
Now we need to make a mirror image of the velour for the passenger side. There are two ways:
1. You can turn the already made piece upside-down and place it on the new uncut velour piece and then just cut it into shape. That has it's drawbacks as in some cars both sides are not mirror images of oneanother.
2. Just repeat the whole process again. This way you can sidestep any differences in the interior.
After all is done we do another test fit.
Attached File  testfit2___.JPG   32.36K   16 downloads
In this case both sides of the interior are joining in the middle just under the center console. If I were able to remove the seat's I could have made the whole carpet out of one piece. But that's in a perfect world. In the real world I just taped down both pieces right next to each other on the right corner of the center console.
After you tape down the second piece. You're done  :yahoo
All you have to do is reassemble the car and show it off  :cheers
Attached File  IMG_0944___.jpg   32.9K   12 downloads
Attached File  IMG_0945___.jpg   32.72K   10 downloads
In some models the interior doesn't have ledges and the floor is even with the diecast body. In this case you can leave a few millimeters more on the velour and let them be fastened down by the diecast body when you reassemble the model. In that case you end up with this:
Attached File  IMG_5295___.jpg   38.59K   13 downloads
Much nicer and real effect.
That's about it :cheers
If you have any questions or ideas they're more than welcome  :cheers
I'll be back
#4 Guest_Bugattitude_*
Guest_Bugattitude_*
  • Guest
Posted 26 January 2009 - 02:06 PM
Great tutorial and superb outcome !! :3tens:
Tks for sharing, T1 :cheers
#5 OFFLINE   jcollege
jcollege
  • 1517 posts
  • Favorite Brands:GMP, AUTOart, Kyosho
Posted 26 January 2009 - 02:19 PM
Nice write up!  I use the same method, with some velour that already has a sticky backing.  Looks pretty nice and its a lot easier than flocking (at least in my experience).
-Jeff
#6 OFFLINE   joeyo387
joeyo387
  • 1055 posts
  • Number of Models:30
  • Favorite Brands:...
Posted 26 January 2009 - 06:54 PM
Looks great! What exactly is velour, where can you get it, and what colors does it come in?
A focused or planned collection can tell a story, while a random collection talks mostly about the collector. Neither is better than the other, it's personal choice - Woobs
My Fastest Cars in History collection and my BMW Motorsport collection.
#7 OFFLINE   Ducati-900SS
Ducati-900SS
  • 4910 posts
  • Favorite Brands:Minichamps
Posted 26 January 2009 - 07:32 PM
Great tutorial, looks so simple a caveman can do it!!!  Great finished look too!
Sean
#8 OFFLINE   993 Porker
993 Porker
  • 2792 posts
  • Favorite Brands:0
  • Proud Citizen of: nz
Posted 26 January 2009 - 08:38 PM
That's a great tutorial, very detailed :3tens:
Thank you for sharing it T1000  :cheers
I was wondering the same thing :question: TIA
Derek
#9 OFFLINE   T1000
T1000
  • 3944 posts
Posted 27 January 2009 - 12:37 AM
Thanks guys. Much appreciated :cheers
Velour is a fury fabric usually made from the skin of animals. Now that's way too expensive and well bad, so I use an imitation made from cotton and silk which gives the same fury properties. And after all I use an old jacket so it came totaly free :giggle There's also a fully synthetic velour that's made from lycra and poly which is also quite good (and I think that it may be even thinner).
As for the colors - it comes in a very, very wide variety. The easiest way is to go to your local fabric/tailor shop and directly ask for a thin fury fabric. Usually for most cars a piece 15x15 cm is more than enough so when you get say 1x1 meters you'll have material for dozens of cars for a fraction of the cost  :ok
Sean
That's exactly why I'm doing it  :giggle I like very simple things as I can't do very complicated stuff with diecasts without clubbing them like a cavey :storm  :giggle
I'll be back
#10 OFFLINE   Autobellissima
Autobellissima
  • 546 posts
  • Favorite Brands:Anything
Posted 29 January 2009 - 04:39 AM
fantastic! i believe you must have released the carpet fabric secrets of the big diecast companies. those don't look far off from model cars that come with carpeted interiors!
#11 OFFLINE   T1000
T1000
  • 3944 posts
Posted 29 January 2009 - 05:11 AM
Thanks  :cheers The look really is as good as stock models but they use a different technique - the classic flocking :cheers
I'll be back
#12 Guest_mforms_*
Guest_mforms_*
  • Guest
Posted 29 January 2009 - 08:23 AM
Thanks man for sharing this valuable tutorial, which I will definitely use for my modifications. I was just thinking of carpeting my models. You're timing's great!! Thanks a lot!!!
#13 OFFLINE   iluda1551
iluda1551
  • 495 posts
  • Interests:Cars, Basketball, Tennis, and God
  • Number of Models:45 and rising
  • Favorite Brands:Maisto, Ottomobile, and UH
  • Proud Citizen of: kr
Posted 15 July 2013 - 12:46 PM
So here's a DIY for carpeting without the flocking work.. You can do it but you can get a realstic feel then flocking. If you've ever felt a cars carpet this might be more better.
So here's what you need..
CAR ( I used 1:18 since it's easier.)
CARPET ( You can use anything but this gave me a realstic feel)
SOME KIND OF STRONG BOND ( I used hot glue )
CUTTING BOARD ( I used a cardboared thing
Step one... Disassemble car..
( Here i did but I can say there will be screws under the car.)
Uploaded with ImageShack.us
Step Two.. Cut your carpet out.. ( Here I got this at my local hobby store for about 50 cents..)
Step three... Then fit it on your car.. ( You can measure or match or however you want to do it..)
Step four.. Glue the carpet on.. ( I used hot glue this might be the easiest..)
Step five.. wait for the glue to dry and put your car together..
now you have carpet on your cheap car that didn't!! And you didn't spend not even a dollar..
Hope this helped!!  :welcome
Currently trying to come back in the hobby
Latest Pickups
1/18 Maisto Mercedes-Benz AMG GT
1/18 Bburago Ferrari California T Hardtop
1/18 Maisto Jeep Wrangler Willys
1/18 Bburago Porsche 911 GT3 4.0
#14 OFFLINE   E Rod_017
E Rod_017
  • 4669 posts
Posted 15 July 2013 - 02:47 PM
I shall try this thanks for posting
#15 OFFLINE   guywithazonda
guywithazonda
  • 3678 posts
  • Favorite Brands:.
  • Proud Citizen of: ad
Posted 15 July 2013 - 05:40 PM
Good job with the carpeting, it makes a huge improvement to the model.
#16 OFFLINE   iluda1551
iluda1551
  • 495 posts
Posted 15 July 2013 - 06:58 PM
Good luck!! But this was really easy compared to flocking!
Yea I thought so too. This car needed a update
Latest Pickups
#17 OFFLINE   tonyg54
tonyg54
  • 5910 posts
Posted 15 July 2013 - 07:23 PM
It looks quite a bit overscaled. I think flocking makes a better option. You could also try white glue as it generally dries clear. But it might not be able to handle something that thick.
#18 OFFLINE   iluda1551
iluda1551
  • 495 posts
Posted 15 July 2013 - 08:11 PM
I know flocking does look better.. I've tired it and turely if you haven't done it a millon times it's a pain in the but... I only done this for the feel... And the money saving  :hope:
Latest Pickups
#19 OFFLINE   acisne
acisne
  • 10816 posts
  • Interests:Cars!
Posted 15 July 2013 - 09:05 PM
*topics merged*
#20 OFFLINE   iluda1551
iluda1551
  • 495 posts
Posted 15 July 2013 - 09:14 PM
View Postacisne, on 15 July 2013 - 09:05 PM, said:
*topics merged*
Sorry man... Didn't notice..  :rolleyes:
Latest Pickups
#21 OFFLINE   wet sellery
wet sellery
  • 220 posts
  • Favorite Brands:Hotwheels
  • Proud Citizen of: be
Posted 19 July 2013 - 12:17 AM
A nice alternative is self-adhesive felt.
#22 OFFLINE   ayaxr
ayaxr
  • 1058 posts
  • Favorite Brands:HWE, AUTOart, Kyosho
  • Proud Citizen of: pa
Posted 26 July 2013 - 10:07 PM
Flocking is a mess.. I've tried it many times and have had less than spectacular results...maybe I dont have the tecnique down right hehe.. but Carefully managing the glue vs the amount of flock used still does not yield me even results that look half as good as some people who post their work here.
Velour would be the way to go for me in the future.
#23 OFFLINE   wet sellery
wet sellery
  • 220 posts
Posted 26 July 2013 - 11:19 PM
I cut templates from a piece of paper and use self-adhesive felt. Here's some pics :
#24 OFFLINE   GroupG
GroupG
  • 102 posts
  • Favorite Brands:Spark & Otto
Posted 26 July 2013 - 11:25 PM
Look for the carpet you can buy for doll's houses. Very cheap for the amount you get.
#25 OFFLINE   iluda1551
iluda1551
  • 495 posts
Posted 27 July 2013 - 11:35 AM
Wow wet sellery where did you get that from??
Latest Pickups
