OttoMobile wheel removal - Disassembling - DiecastXchange.com Diecast Cars Forums
13 replies to this topic
#1 OFFLINE   manitoulin
manitoulin
    A smaller scale piece is not always bad...
  • 16 posts
  • Favorite Brands:Kyosho
Posted 10 June 2012 - 01:26 PM
Perhaps I missed seeing the post, but is there an easy way to remove the wheels from an OttoMobile car? I would like to mod my Scirocco.
Thanks,
Joe
  • Attached File  sci.jpg   111.75K   0 downloads
Edited by manitoulin, 10 June 2012 - 01:27 PM.
#2 OFFLINE   CitroFriend
CitroFriend
  • 1391 posts
  • Number of Models:50
  • Favorite Brands:OttO/Norev/AUTOart/GTS
  • Proud Citizen of: lt
Posted 10 June 2012 - 02:33 PM
Unscrew botom.Take it off.Take wheels off :)
#3 OFFLINE   manitoulin
manitoulin
  • 16 posts
Posted 10 June 2012 - 02:47 PM
Really?
Each wheel comes loose from that procedure? I can then replace them that way?
#4 OFFLINE   audirs6
audirs6
  • 3108 posts
  • Interests:Photography
  • Proud Citizen of: si
Posted 10 June 2012 - 02:52 PM
Yes.. It's so easy to remove wheels..
#5 OFFLINE   manitoulin
manitoulin
  • 16 posts
Posted 10 June 2012 - 03:15 PM
Cool. Thanks :o)
#6 OFFLINE   Mike K
Mike K
  • 5459 posts
  • Number of Models:100-110
  • Favorite Brands:CMC, Autoart, UT, Cult, Tecnomodel
Posted 10 June 2012 - 04:30 PM
Moved to proper section of the forum  :occasion14:
#7 OFFLINE   manitoulin
manitoulin
  • 16 posts
Posted 11 June 2012 - 12:44 PM
Perhaps I should have been more specific. Will doing what was suggested allow me to remove the wheels form the axles?
#8 OFFLINE   broz13
broz13
  • 417 posts
  • Interests:Basketball, motorsport in general
  • Favorite Brands:AutoArt
  • Proud Citizen of: it
Posted 25 September 2015 - 05:38 AM
Asking the same question... I have a Peugeot 106 by OttOmobile, and I'd like to change the wheels.... But it seems that they are glued somehow, how can I remove them?
#9 OFFLINE   Craig
  • 30951 posts
Posted 25 September 2015 - 05:42 AM
You are best off taking the car apart (really easy) as they use a steel rod as the axle. Then get your new wheels & mount them up on a new axle. If you try to get them off of the original axle you might break them.
F**k you Photobucket.
#10 OFFLINE   broz13
broz13
  • 417 posts
Posted 25 September 2015 - 05:56 AM
I've already took the bottom of the model apart, and I've seen that there is a single rod that connects the two wheels... Then I only need the steel rod, 4 new brakes and 4 new wheels
#11 OFFLINE   jusali
jusali
  • 1341 posts
  • Favorite Brands:Too many to choose from
Posted 25 September 2015 - 08:27 AM
Twist and pull off the axle, it's very easy
#12 OFFLINE   Speedphreak1983
Speedphreak1983
  • 6 posts
  • Favorite Brands:Autoart, spark, sunstar
Posted 07 July 2018 - 11:09 AM
Almost all resin cars use metal axles to hold the wheels.
#13 OFFLINE   slartibartfast229
slartibartfast229
  • 4442 posts
  • Favorite Brands:Otto
  • Proud Citizen of: ie
Posted 07 July 2018 - 11:16 AM
What I do with Otto and GTS is remove the axle as outlined above, then twist the wheels in opposite directions while tugging lightly.
One wheel will go before the other, which should also be loose.....
#14 OFFLINE   emanuil.hv
emanuil.hv
  • 340 posts
  • Favorite Brands:GT Spirit <3
  • Proud Citizen of: bg
Posted 14 September 2018 - 10:57 AM
Preisman explained this pretty well here: http://www.diecastxc...rit-991-models/
My collection - click here ^
