Roll Cage - Interior Works - DiecastXchange.com Diecast Cars Forums
Roll Cage
6 replies to this topic
#1 OFFLINE   Damon Paterson
Damon Paterson
  • 1952 posts
  • Favorite Brands:AArt,HWE,GMP,Hwy61,Kyo,Mchamps.
Posted 19 November 2013 - 07:37 PM
Just wondering if there is a standard size of rod used when building a roll cage in a 1:18 model?
I have 2.5mm styrene rod to use in my build, it looks proportionately correct in the model, whereas I think 3mm may be a bit too big. But are most roll cages built in 1:1 cars the same size, which to correct scale would make 3mm the rod to use?  :icon_scratch:
Any help is appreciated.  :occasion14:
#2 OFFLINE   ibj40
ibj40
  • 5107 posts
  • Favorite Brands:.
Posted 19 November 2013 - 08:30 PM
From the Sports Car Club of America Rules:
Vehicle Weight    Material
Without Driver Mild Steel    Alloy Steel
Up to 1500 lbs.    1.375 x .095 1.375 x .080
1500-2500 lbs.    1.50 x .095 1.375 x .095
Over 2500 lbs.    1.50 x .120, 1.50 x .095
 :occasion14:
Edited by ibj40, 19 November 2013 - 08:30 PM.
#3 OFFLINE   Damon Paterson
Damon Paterson
  • 1952 posts
Posted 19 November 2013 - 09:14 PM
Thanks Jim, seems 1.5" converts to 2.1mm in 1:18 scale, so 2.5mm rod is more than enough.
Thx.
#4 OFFLINE   La modz
La modz
  • 858 posts
  • Interests:1-18 diecast models.tropical fish keeping.
    moddifiying real cars
    muy thai boxing
  • Favorite Brands:auto art
Posted 05 December 2013 - 02:36 PM
I use 3mm styrene rods as used on the rsr space frame
#5 OFFLINE   B1N9S
B1N9S
  • 933 posts
  • Proud Citizen of: uk
Posted 15 December 2013 - 05:56 PM
I tend to use 2mm on mine.  But after seeing Lala's RSR I might be converted to 3mm !!!
#6 OFFLINE   thearea-71
thearea-71
  • Banned
  • 536 posts
  • Favorite Brands:thearea71
  • Proud Citizen of: it
Posted 10 January 2014 - 09:59 AM
I use 3mm Tamiya clear rods and they work fine, you can easily bend and no heat is needed
#7 OFFLINE   oyetis
oyetis
  • 645 posts
  • Interests:Rally & 1/18 Die-cast Rally Car models
  • Favorite Brands:AUTOart - Kyosho
  • Proud Citizen of: tr
Posted 24 January 2014 - 10:24 AM
this might give you guys some idea with 3mm Tamiya Soft clear rods....
as Marco mentioned, they are easy to bend with fingers...
Happy Collections,
Omer Yetis
Check out my Custom build Rally car projects...
http://www.diecastxc...tis#entry831590
or Find me on Facebook....
https://www.facebook...22491/timeline/
