1 - 10 of 10 Posts
Hi guys, I'm repainting my Ferrari F40 using the Testor Model Car Spray Paint set.
I wasn't even done with the first coat and pretty much the tiny bottle is almost used up.
Was I using too much paint or is it supposed to do that?
Thx guys.
Those spray guns can eat a up one of those small bottles of paint. As long as you used a light spray technique and the paint isn't to thick you should be fine. :mrgreen:
phew...thx...
I guess I should stick to spray paint by cans?
Hopefully the car will turn out ok, this is the first ever diecast car I've ever repaint... :angel:
Was it a smooth spray job. :?:
I used the aerosol air spray and a small bottle of Testors paint to paint a UT vette last year and when I finished it looked like brick stuco.
I now use this model to test all my paint on. ;-)
If, after you apply the paint, it looks glass smooth and perfect, you've applied it too thick. Check for run marks/streaks on the body as well, as that's another tell tale sign.
Discussion Starter · #6 ·
it actually doesn't look glass smooth...it's orange peely...lol
i read somewhere that I need to use some sort of paint restorer or something to buff it first?
You guys have any suggestion...?
Depends how rough...you can use automotive polishing compound to smooth it out, just be careful not to remove too much paint, otherwise, you're back to square one. You actually want a little bit of orange peel when you paint.
thx for the tip..
which polishing compound do you guys recommend?
I painted my 1:24 silverado with a tamiya red spray can and i will say it came out smooth and dripless, as i applied it in single thin coats, for the very last coat you put on a slightly thinker coat but not too heavy otherwise it will run. If you have orage peel it means you've put too much paint on it at one time. In painting/spraying real cars and other things if you get bad orange peel you really need to sand it back and reapply the colour again. I love being a proffesional spray painter :), so many things that one can paint :) and so many colours to choose from :)
Nothing like taking a blank canvas.. eg a car and restoring it to showroom condition.. so satisfying :)
John
Sorry but I am through using Testors paint. :pke: They are terrible, or at least the ones I used so far are. Seems that every testor paint I've used came out like crap, all the other paint brands seem to work.
1 - 10 of 10 Posts
