This was one of the trickiest bits of the project so far. It started off with me needing a second model for the engine to make the V6.
Two Smart 3-cylinder engines + gearboxes
I removed the gearbox from each engine and marked where I was going to cut. I cut just to the right of one of the stubs for the belts on one engine and past the stub on the other engine with a coping saw.
Engine and gearbox
I smoothened off the rough edges and joined the two engine parts to make the V6 while they share the same gearbox.
You can see the seam of where I cut in this picture where the engine doesn't have the belts attached.
This picture shows the V6 sharing the same gearbox.
And here's a closeup of the V6.
Because Bburago (unsurprisingly) didn't worry about simulating a fuel tank, I hand plenty of space to mount the engine.
The engine isn't finished yet as I still have to do the wiring for it. :cheers
Engine and gearbox
