Up next for review is the ERTL 1969 Plymouth Roadrunner. I've had this car so long I forgot when I first got it.. This is my first medium quality car review, so I may seem biased on the quality. I'll try my best not to do that. To start off, I've had this car so long, I threw away the box long ago, so no review of that. Let's jump straight into the car..
I just took this out of storage, and as can be seen it is pretty dusty and grimy. Although this car is aged, one can still the well applied Jamacia Blue with hood stripes, as well as the painted air grabber, The body is straight and all shut lines fit appropriately. All of the trim on the car is plastic, including the door handles, wipers, bumpers and grille. One weird thing is the badge on the doors, which are just obvious stickers. When the badges on the rear, are actually paint badges.
Up front not much more can be said except the grille is not through and the license plate is just a sticker. No frame or anything. I'd recommend taking them off..
On the rear, only to thing to note are the exhaust tips, which have been barely drilled except being painted. Kudos for doing that.
The Magnum 500 wheels on this car are plastic and are fitted to not that bad redline tires. They feel though as they're solid rubber. The front wheels steer with the steering wheel as it should well.
The interior is just... there. It looks good from the outside? Just don't open the door. If you do make that mistake, you're greeted with a sea of plastic and lack of detail. Sitting in the bench seat, you're greeted with no pedals, an awkward shifter and a flat dashboard. clearly this car was made to sit on the shelf and viewed from more than ten feet away.
Yeah.... the trunk doesn't open........ so,,,yeah..0/10
Under the hood(which opens on fake hinges), there's not much to see. You have your plain motor, connected to the radiator and the transmission. That's about it. Best thing under the hood is the horn. It just sticks out there in the corner.
The bottom is detailed, but not correct. The front and rear suspension are modeled pretty well, just in plastic. Not much else to say.
Overall, the car is nice, it's just plastic. I've heard the Supercar Collectibles 1969 1/2 Roadrunner is a lot better, but I haven't gotten my hands on it yet. This car is only good when viewed from either a distance away or among a group of other diecast. If anyone happens to own one, do you recommend it?
