Have you ever wanted to add a little bit more taste of realism on your model cars?? Well this is for you then! A simple free DIY
Things you must obtain
Printer (Does not matter what type it is as long it has ink you'll do)
Scissors
A4 paper
Card stock paper (Optional)
A car (No dip)
A good working station
Step one: Obtain magazine cover and back (Optional)
Now this step you can google or scan a real magazine up to you so I'm not going to go detailed about this step.
You do not need a back but if you want one go on bro!
Step two: Print cover
BUT MAKE SURE YOU HAVE THE RIGHT MEASUREMENTS!
I used width: 1.5 cm Height: 1.9 cm. If you find a closer scale to 1:18 please do tell
Step three: Cut cover and/or back and/or base and put it all together
Also this is optional but highly recommended add a layer of clear type on top to get a glossy look
Cut it and add a cardstock back or some sort of hard base to the back of the tiny cover so it doesn't fall apart.
Then add the back to it. You can glue or use double sided type as long as it works lol
Sorry for the crappy phone pics it was just too small lol
Uploaded with ImageShack.us
Step four: Well your done so go out there and post pretty pictures
Scissors
A4 paper
A car (No dip)
