I never really liked the way my 360 sat, so with my new Stradale on the way I figured now is the time to work on the Spyder. I first took the 360 apart, pretty easy, just 6 screws on the bottom, then took the wheels off, one screw at each corner. The wheels each slide onto a post with a stop to keep them from going all the way up. The way I lowered it was to use a dremel tool and a cut off wheel attachment to shave away the top of the wheel mount(the part attached to the wheel) not the post that the wheel slides onto. The wheel will now sit slightly lower when sitting on a table but the original ride height can be regained by adding a washer or two if you decide you don't like it. There is a bit of conflict with the wheel wells but not much. I like the new ride height enough to live with it at least. OK OK I know shut up and show us the pics right?
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
DiecastXchange Forum
A forum community dedicated to diecast owners and enthusiasts. Come join the discussion about collections, displays, models, styles, scales, reviews, accessories, classifieds, and more!
