Guest
·Subject: Maisto Lamborghini Murcielago.
I've always liked Maisto for their use of springs as working suspension. Makes it easy to lower their models. Just cut the springs and I'm good to go. Problem was, cut away too much of the spring and I had a car that's too low and I can't change it back.
So now, instead of cutting springs, I use drinking straws instead. I measure the amount of drop I want and cut the straw in appropriate length. Put them in place of the springs and I'm done. If the drop is too much or not enough, all I have to do now is cut out another piece and try again. I can play around with different height until I find the one I like. I keep the springs in case I want to return the model back to stock form. Sure the model doesn't bounce up and down anymore but that's not what I need in a model. Have fun.
