Hi guys!
Some of you expressed interest to learn more about how I did my studio-like low-light pics of the Uhlenhaut Coupe.
http://www.diecastxc...ut-coupe-again/
I'm happy to do so - absolute no secret about this. I only hope that at the end your are not disappointed when you see how simple the set-up is...
1) Equipment
A good camera and a good lens are key for good results, of course. I'm using a full-format DSLR and 24-70mm zoom lens.
To achieve best results I only shoot my models by using a stable tripod (also see below: shutter time).
2) Some basics w.r.t. to shooting (hope I'm not boring you with matters of course)
No automatic function of the camera is used, everything is managed manually:
- focus: I use the camera's live view and magnification function to precisely focus the lens on a central detail.
- aperture: Use max value (e.g. 22) for maximum sharpness over a wide area.
- shutter time: When operating with max aperture value you have less light available and need longer shutter times (typically 5-30 sec, depending on available light and iso value) - making the use of a tripod inevitable.
3) "Foto studio"
As some of you might know I have only very limited space available - for my models as well as for a foto studio.
So when I shoot my models I do it on a white side board which carries our TV and has roughly 20cm free space in front of he TV. For daylight shots I need a bright day to have the appropriate light.
4) LIGHTING for low-light shooting
For those special pictures I use 2 additional ingredients:
a) Create a dark background by use of black fabric (e.g. cloths or scarfs)
b) I use the indirect light of my TV screen for lighting the model - sending a constant uni-color picture from my smartphone to the TV. All other lights in the room have to be down, of course.
To give you a better impression I add a quick smartphone picture of my "foto studio":
And that's already the whole "trick" - the rest is done by processing and improving the pictures with Photoshop.
So really nothing spectacular as you can see...
1) Equipment
3) "Foto studio"
