ok, for some weird reason i cannot make the words blue. it feels naked!!! i will have to fix that later
ok, i fixed it!!
ok, i fixed it!!
Hobby and craft stores. They usually carry at least a few kind of masking tapes there. The ones you want are thinner, flexable, and strong. I'd like to use ones specific for plastic models. Just make sure the edges are firmly attached to the surface before you spray the paint. By the way, these type of tapes are usually 5-8 dollars per small roll. It's a good idea to use it along with some cheaper tapes to save some dollars (i.e. expensive for the edges and cheaper ones for the center). As for where to get 400 grit or above sand papers, most auto stores carry them. I am sure you can find some at Home Depot as well.Louis,
Thanks for you input,![]()
where do you buy your masking tape, as Ise the cheap stuff and it seems to be harder to tape everything off than actually painting. :?:![]()
