you can find three quick pictures I took of my NSX spider. I'm refurbishing it and I decided to remove that crosspiece in the middle of the front intake. So the two intakes on the side are now covered with a chrome grille but the front is currently open. Should I cover it up? If so should I use the same angle for grille as on the side intake grilles or should it be straight up and down? Also what color?
The only thing I might do differently is to use mesh material that's got smaller openings for those side vents. One idea is to tear apart a tea-leaf strainer ball. It's got really tight mesh with fine wire than can be contoured very easily.
The CLK-GTR is by maisto and is a repaint. I first tinted the windows on the inside but it permantely messed it up which scared me quite a bit till I got some clear coat. I put on the same gloss black paint as on the rest of the body and put a clear coat over it. Not quite as good as it could be....but it works.
I also removed the chrome backing from the headlights and took out the bottom grille. I also added a grille to the brake vents just behind the front wheels.
Then of course I had to add on some wicked gaudy dub rims :angel: I should have some more pics of it up with the spinners on very soon and it will get to share an album with another car.
Thanks for your opinions guys! :sm: Always nice to hear from ya
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
DiecastXchange Forum
A forum community dedicated to diecast owners and enthusiasts. Come join the discussion about collections, displays, models, styles, scales, reviews, accessories, classifieds, and more!
