1 - 9 of 9 Posts
Here is a way that I found to make oil dip sticks on budget models.
First you have to get over the fear of taking a diecast appart. Most are easy and the body and chassis come appart by removing 6-8 screws. I have found that the most problem that I have is with the steering shaft, but after you have done it a few times, you will be able to do it blindfolded.
Start by taking it all appart and removing the engine from the chassis.
These are some of the tools that I use:
-a long nose plier to make the curb of the handle
-a wire cutter
-a wire stripper.
-I also use some miniature drill bits to make the hole in the block and glue the dipstick to it.
You know all those wires that are used to hold toys to packaging? They make great source for this.
First, cut the wire the right length and strip one end for it to go into the block and the other end for the handle.
Cut a small piece to the "cap" of the handle.
Bend the handle with the pliers and bend the whole thing to clear the exhaust.
Now paint the "tube" to match what the manufacture used. Some are painted with the block and some are painted sepparatly. In this case Chrysler painted the Tube white.
Also, paint the "cap" silver to match the dip stick.
And here it is on the finished engine.
-a wire cutter
-a wire stripper.
Great article answered questions for many of us I'm sure.
1 - 9 of 9 Posts
