I've never used it, but if its anything like their other products, must be awesome. :mrgreen: :mrgreen:
Removing numbers from windows?? Sounds like something you do after a day of drag racing. ;-) Around here, the numbers are "painted" with a giant marker on a side window.I used an old toothbrush and white toothpaste to remove numbers from the windows as well. It works treat but takes a while to do. :sm:
Be very careful about the hazing of the windshields as I have ruined models with inappropriate cleaning solutions resulting in hazed windshields. Once they were hazed up, nothing worked.i wuz thiking of buyin it to help remove the hazing/milkish stuff on my car's windscreens n windows... dunno if it'll werk though
Wow thats good, so just to verify, #2 and #1 are safe to use on the paint and other surfaces of most scale models...?This is what you need. The Novus plastic polish system comes in three steps, but for most modelling, all you need is the first two. Check out this video. It even has the Bburago Countach as an example of scale models.
