I'm no expert, but maybe I can give you a little input.
Both of these paints are going to be thick, for a lack of a better word.
If your doing spot painting, it shouldn't matter too much as you can apply evenly as needed.
sounds like your painting over a small area, if this is the case lay your coat of paints, then use some fine grit sand paper to smooth it down to match the rest of the surface. That may be the toughest part as you may have to shoot the entire car with a clear coat to even out the look.
If you have pics of the area, that may yield a better idea of the area of painting in question.
