I'm not really into the whole Dub thing but I really like this car and got a good deal on it!
Here's what I started with:
First thing I did was unscrew the three screws that held the floorpan to the body. Then the wheels simply pulled off.
Then I removed the interior and used a screwdriver to push on the pins that hold the brake calipers.
It took a lot of effort and a couple pairs of pliars to get these blue rubber boots off. I then removed the axel from the chassis.
Next I took a hobby knife to make the axel guide holes a little bigger. I used some plastic scrap plastic from Evergreen to make the new axel. This diameter axel is the perfect size as the holes in the back on the donor car's rims.
I superglued to donor car's wheel to one end of the new axel and slid it through the enlarged holes. I made the axel a little long so I could cut it down until the axel length was just right.
After a little trial and error, I got the axel length just right. Then I superglued to other tire to the axel. I followed the same steps for the front and this is what I ended up with before the body went back on.
And now with the body on!!! Much better looking than with the bling-bling tires I think!!!
Sean
A model saved from a fate worse than death!
Thanks for the tutorial Sean! The Charger looks 100% better :cheers And now you have a spare set of whels that might look good (and more to scale) on an 1/18 model :giggle
I think the dub wheels will end up being diorama fodder more than anything. They would look good on the back of a large scale OCC bike!
Give me a classic ground pounder with a set of Kragars and fat Micky T's any day!!!
Sean
Discussion Starter · #6 ·
Funnny you should mention that!!! I picked up two more Maisto Pro Rods to De-Bling!!!
I'm hooked!!!! :help
Sean
